DHollaen
Hi all,
I hope that some one can help me with my TV and my XBOX ONE S. So far, I'm pretty disappointed with the audio setup.
Frankly speaking, it seems that the engineers simply forgot that an UHD-player should support HD-sound, too.
But lets's start with my setup.
TV Sony 65XD8505
Yamaha YSP-4100 7.1 soundbar
XBOX ONE S
Current connections:
XBOX ONE S directly connected to TV via HDMI 1 (soundbar does only support HDMI1.4a)
XBOX ONE S connected via TOSLINK to soundbar
TV connected to soundbar via HDMI4 (ARC) or TOSLINK
So far, I haven't figured out on how to get 7.1-Sound from my XBOX ONE S playing (UHD-)Blurays to my soundbar (eg. DTS-HD 7.1). I already selected direct bitstream in the Bluray-Player's settings. But it seems that the direct bitstream does only work via HDMI but not TOSLINK. Is there any way to have the uncompressed soundtrack being played via TOSLINK to my soundbar? If not, whats's the sense of having an optical output if it can playback re-encoded Dolby/DTS 5.1 only?
BTW: The soundbar is not the bottleneck as it can play 7.1-sound from my old bluray player via digital out (TOSLINK or COAX) without problems.
Is there any good HDMI-AUDIO-Extractor which supports 60HZ-HDR10-HDCP2.0-7.1 which I could use to solve the issue? I would prefer a direct connections via TOSLINK, though.
I chose the XBOX because of the UHD-Bluray support but with re-encoded sound is pretty useless.
Kind regards,
Daniel
TV Sony 65XD8505
XBOX ONE S
Kind regards,
Daniel
