Quantcast
how to connect mp3 player to car audio
JonLeach
i'm thinking of getting a ipaq or iriver 20g, but need to use it in my car.
i have a nissian primera, with a kenwood autochanger that uses the radio to plumb in the CD player.
can i use the cd changer input or do i need something else.
Ta
Jon
graham.myers
becuase I used an autochanger the aux connector on the head unit was busy. I had to use an fm tuner plugged into the mp3, and then tune the radio into it.
if you have a cassette in the head unit you could use an adaptor plugged into the headphone socket of the mp3 player
JonLeach
my autochanger plugs into the fm ariel. so could i use that??
i will try a portable cd player before buying i think.
Jon
