How to connect laserdisc RF to amp without RF in?
Discussion in 'AV Receivers & Amplifiers' started by Pottsy, Apr 15, 2003.
  1. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    I'm thinking of ditching my old Yam 3090 for a new Pioneer 2011.
    Problem - the 2011 doesn't have RF in for Laserdisc sound. Is there a little demodulator box available for this or should I ditch the idea of either LD's or the 2011???
    Thanks for any help,
    Pottsy
  2. stevelup
    stevelup
    Aug 13, 2002
    6,142
    Swindon
    +855
    Yes, you need a demodulator. They get sold on here from time to time. I think the last one (a Kenwood one) went for £45.
    Steve
  3. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Another alternative (if you have the space) keep your old Yamaha amp, use the pre-outs from the Yamaha into the multi-channel input of the 2011.
    The 2011 will then decode everything except for the Laserdisc ... which will be decoded by the Yamaha.
    Vikki
  4. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    Thank you both! I think the more elegant solution will be a demodulator - I'll keep an eye out for one....
    Andrew
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Yes ... the modulator will be definately more elegant ...
    Not sure if this is any use to you ... http://www.soundlabsgroup.com.au/bde/bde_rf_demodulator.htm ... but it's an RF Demodulator board which can be fitted internally to a LaserDisc player or could be mounted in an external box.
    Been wondering about getting one myself ... but it's not exactly cheap.
    Vikki
