How to connect HTPC to RGB Scart
Discussion in 'Desktop & Laptop Computers Forum' started by CrispyXUK, Jul 24, 2003.
  1. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    Land of the Living, Essex
    +33
    Hi all,
    Just thought I might make you all aware of the ArcadeVGA card (ATI Radeon 7000) video card from Ultimarc.
    I have been reading up on this in certain forums and have found that all video modes are locked at 15hz H (?) that are compatible with RGB scart TVs directly from the VGA port (with the correcly wired cable). this should allow you to use all allowed refresh rates and resolutions.
    Hope this is of help, I will be getting one in the next few weeks and I will report back with some results.
    Ultimarc Website
  2. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +843
    I don't know much about scart RGB, but presumably this should present the best possible way to connect an HTPC to a regular scart capable PAL TV? (ie. better than a transcoder)
    Is scart RGB 625 interlaced lines, and 720 columns? Would you need to define the resolution in powerstrip for this to work?
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    The card is designed with Arcade Moniters in mind so that you can send the excact correct signal (Res & Frequency) to it from MAME etc.
    Arcade moniters are basically the same as using the RGB scart on your TV, its comes with built in modes including 640x480i and 800x600i I see no reson why we cannot create a 720x576i mode.
    Payday is Friday so I will order and test :)
  4. Ivan8192
    Ivan8192
    May 2, 2003
    24
    Birmingham, UK
    If you've got a Radeon card, which can produce a composite sync + interlaced video signal, it is possible to connect the VGA output directly to an RGB scart TV input:
    http://www.idiots.org.uk/vga_rgb_scart/index.html
    Takes a bit of messing around in PowerStrip...
    Ivan.
  5. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    This card has all the modes built in and will work on your TV straight away without any adjustments though.
  6. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    I'd be very interested to know how well this works, keep us posted.
    Owain
  7. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    Yeah me too ;)
    I cant get projector till next year so I will get one of these, I just hope it will run UT23k jedi 2 & doom 3, but as I will only be using max of 800x600 for games I think it should be fine.
    Hopefully my DVD-v will be up on ebay soon if it works oout ok
  8. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    Have a look at this website for a bit more info mamescart
  9. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +843
    It looks like it will work for both 4:3 and 16:9 TV's - with the right value on the scart control pin (pin 8). I may have to get myself an old PAL TV just to try it! (and a radeon card...and the catalyst 3.4 drivers...)
    I would imagine that a resolution of 720x540i might give the best results. 800x600i might give you overscan problems - unless you are able to adjust your TV.
  10. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    The ArcadeVGA uses custom drivers if think, I wont be getting one for another week as I have just paid for my centre speaker :), so unless someone gets one before the next two weeks we wont know
  11. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    here are some shots of the ArcadeVGA wired to a sony 21" RGB scart tv running mame games, looks pretty good to me.
    Surely we can modify an ATI card to do 15hz display like this ArcadeVGA? anyone know were to star?pics
  12. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    The ArcadeVGA card has a custom BIOS. If you can grab a copy of it, and find a similar specced ATI card, then I guess it's possible to replace the BIOS with the one from the Ultimarc card.
    I suspect for the hassle involved, it's much easier just to buy the ArcadeVGA card.
    I've bought a couple of I-PACs from Ultimarc, and they were quite helpful when I ran into some problems, so the company gets a thumbs up from me :)
  13. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    could any clever programers out there make a bios for <insert graphics card here> so it can be connected like this?
  14. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +843
    I think most of the information is in Ivan's earlier link
    It seems like you should be able to use most radeon cards. The problem might be the PC POST screens, which I suppose could fry the TV. The solution would be to boot the PC before connecting the TV. But it is not ideal. What monitor would you use to switch the resolution in powerstrip? I guess you could paste the timings into powerstrip using a regular monitor, then switch resolutions (losing sync), and then connect to the TV. From then on Powerstrip could set the resolution at windows startup, but you wouldn't want to turn-on the TV until windows had fully started.
