Question How to connect an external antenna to JVC Videosphere
BuzzBoyDragon
I have been given a JVC Videosphere television and would like to connect an external signal to it.
There are 2 black “ports” on the back labeled VHF and UHF but I have no idea how to plug into them.
I plan on running an RF signal in from a VHS player, so need to find what kind of connector or terminals I need to use.
Any assistance is greatly appreciated.
Thanks in advance, John
BuzzBoyDragon
Thanks, I had seen that video but the setup looks really dodgy (refer picture... I would like something more secure).
Was actually hoping to find a proper plug for this kind of “socket.”
Wonder if 2mm banana plugs would work.
mikej
This is the type of plug you need, taken from this page.
Google doesn't give any other results so I think you might struggle to get an original plug, in which case a 'bodge' will be justified ! Presumably, the closer the width of a suitable connector is to the width of the hole, the more secure the fit will be.
Podcast: Philips TV Launch Event, Soundbar vs AVR, Samsung EzCAL and more...
