Im with pipex broadband and want to connect my xbox to xbox live but i only have a usb modem. is there a way to connect it without having to buy new modem and router any help would be gratefull
yes to connect the xbox to your pc ethernet card if you have one with cat 5 crossover cable and use internet connection sharing in windows, the pc has to be on same time as the xbox though
otherwise you could buy this adsl modem/router and use that
Yep, ICS works, but if you've a rubbish computer like me, you'll find it'll crash when you use XBox live. I bought a Speedtouch 530, which has both ethernet and USB, so no more probs
