how to connect a md recorder
Discussion in 'Hi-Fi Stereo Systems & Separates' started by alby*, Sep 14, 2004.
  1. alby*
    alby*
    Apr 14, 2004
    27
    hi i,am adding a md recorder to my system.i have connected the line in/out to the amp (yam dsp-ax640se), is it necessary to run a opt/cox link to the cd player?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,436
    Rainham Essex
    +2,470
    If you want to record from a CD to MD then by connecting an optical or coax lead between the 2 will give a digital copy that should result in very little loss of quality.
    Otherwise the connections you have made are good enough for listening to a MD recording and even an analogue recording from CD to MD should be fairly good quality.
    So basically you don't need to use an optical or coax lead between the MD & CD, but it will give slightly better quality recordings if you do.
    Mark.
  3. alby*
    alby*
    Apr 14, 2004
    27
    cheers i'll use a coax cable as well
  4. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    Plus if you use Digital link you will not need to bother about recording levels as it is a digital stream. Plus it gives you track divides without having to set the 'add track break after certain pause in music' option which sometimes gives curious results.
    Reg
  5. alby*
    alby*
    Apr 14, 2004
    27
    ah,more knowledge thanks all
