How to connect 3806 to TV to get OSD ?
DarkDogZA
Title says it all. I cannot seem to get the OSD from a 3806 to the Pio xde plasma.
I am using the HDMI sockets on both.
Is there a setting I should be changing.
Tx
-Kevin
Jase
Page 15 of the manual mentions about the OSD via the HDMI output. Says the Analog to HDMI Convert must be ON.
Eddy Boy
With display and amp turned on press the STATUS button under the front flap, see whta monitor information is gives back, may need to press it a few times.
Jase
Forgot to mention. The OSD is output at 480i/576i so if the Pioneer can't accept those signals via HDMI you'll have to use Component, S-Video or Composite.
DarkDogZA
Thank you - that was the issue. I now have a jumping? (rolling?) picture.
but its a start!
12 promises
Go To Setup,.............go To Video Setup,...............go To On Screen Display,.....................select Display Mode 2.
MannyMore
Thanks mate found this worked on mine ! :thumbsup: simple when you know how :)
Cheers Tony
