how to config nethostfs for IRSHELL- help plz
Discussion in 'PS Vita Forum' started by Simba, Jan 2, 2007.
Tags:
  1. Simba
    Simba
    Apr 11, 2006
    6,354
    Scotland
    +819
    hi guyz... so far iv been able to pretty much homebrew-ify my psp in almost every way apart from getting nethostfs to work for IRSHELL 3.1 so i can access my files and the like using wifi from my pc on psp. im on the 3.02 oe-a fw (not had a chance to get 3.02 oe-b on it yet). whats really getting to me is that i cant get nethostfs to work at all. my wifi is setup and i can browse the net perfectly on the psp.
    when select toggle nethost in IRSHELL i get an error saying it cant connect.
    iv tried to use the irshell configurator but still no luck.
    can anyone make a quick walkthrough to get this working.......plzzzzzzz :thumbsup:
    simba
  2. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
    http://forums.qj.net/search.php
    searching for 'nethostfs 3.02' results in a few other people having similar problems... verdict seems to be that it doesnt work 100% on 3.02.
