How to clean front of Rear Proj TV
Discussion in 'General TV Discussions Forum' started by mattblue, Sep 3, 2004.
  1. mattblue
    mattblue
    Total noobie to the AV forum, just have a question,... I own a Toshiba 43" rear projection TV and have somehow managed to get a few spec of c**p on the front of the monitor, what is the best way to clean the screen as all the userguide says is to use a dry cloth??... well that aint working, so any help would be great.
    Matt :thumbsup:
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    I have had good results with my plasma using a micro fiber cloth from Aldi. It really does do the job and for 99p if it dont work, what have you lost? :)
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Well, I would have thought 99p, or is it a trick question? :suicide:
    I use the vacuum cleaner on blow (if you'll pardon the expression) and finish off with a feather duster! :laugh:
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Glad we've got that sorted, David! :thumbsup:
    Seriously though, I can understand people being concerned with what is obviously a somewhat fragile item.
    (I seem to remember one forum member recently, whose 2 year old decided it was a dartboard or similar!!!)
    My 46" Philips screen cost £400 to replace (fortunately under the guarantee as it had warped).
    So, Matt, whichever method you use: BE CAREFUL!
  6. mattblue
    mattblue
    Hi People,
    Thanks for the replys - tis not as simple as dust unfortunately, tis like a stain mark on there... is there any polish or a cleaning product I can use??
    Matt
  7. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    My kids kindly splashed something sticky on the screen of mine....I found that a slightly damp cloth used very gently did the trick,but had to be repeated a few times to remove all of the stuff from the ridged non-reflective screen.
