How to clean a LCD Screen?
Discussion in 'LCD & LED LCD TVs Forum' started by nogimmix, Sep 10, 2005.
Tags:
  1. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    Just a quick question.
    What is the best way to clean a LCD screen?
  2. Caprylate
    Caprylate
    Aug 1, 2005
    84
    +3
    Socks, they seem to work better then you'd expect.
  3. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    I bought a good quality microfibre cloth (I think it was meant to be a facecloth) and just use that with a little bit of water.
  4. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    Hopefully you mean clean ones ;)
    I've got some screen wipe thingies, do they work?
  5. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    Best not to; a lot of these things are designed for CRT monitors (glass) and even then, they usually contain chemicals which can damage the coating of the screen.
    I'd just stick with water if I were you.
  6. shrek101
    shrek101
    Mar 11, 2005
    81
    +5
    I bought some paper tissue type cleaners especially for LCD at Aldi early this year. I then dry them with a microfibre cloth which I bought from Wilko's so prevent smearing.
    EDIT on the wipes it says "for use on LCD, TFT, scanners, monitors and coated glass" They were about £1.99 for a 100 but Aldi havent had them back in stock but I am sure I seen them else where I know betterware sell them.
  7. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,428
    East Yorkshire
    +313
    PCWorld sell proper TFT/LCD screen cleaning tissues that are moist but don't contain alcohol. I wouldn't advise using tap water as it contains impurities and you'll end up with a screen with smear marks on it. Trust me I've tried it. Best use a soft dry cloth if you can (to remove dust) or the cleaning tissues I mentioned if the dirt is a little more persistent!
  8. Andy M
    Andy M
  9. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I bought a cleaning kit from eBay which seems to work without damage. It includes a brush for dust, a spray of some sort, and a cloth.
  10. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
  11. freekb
    freekb
    My LG screen came with a special cloth, very felt like, but the kind that doesn't leave fibres on the screen. Sort of a combination between microfibre and felt.
  12. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    de ionised water and a soft cloth is all you need,
    finger prints and any other marks wipe away and with de ionised water it leaves no streaky residue
  13. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    You obviously don't use the right kind of cloth or the wrong type of water An e-Cloth (microfibre) will not leave any marks on the screen. You only use enough water to make the cloth plyable.
    My TV manufacturer says use water and a soft cloth, nothing else.
  14. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Once I'm done cleaning, I occasionally have some marks. I have to wait til they're dry then use another dry cloth and rub them out.
  15. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    de ionised water will stop the smearing, its only chlorine and flouride that leaves streaks,
    i have a reverse osmosis water filtration system to purify water and this does a perfect job (bit expensive for just cleaning tv screen) it also cleans the windows streak free as well as the car.de ionised water is pretty much the same as far as purity goes and cheap enough
  16. peahead
    peahead
    Dec 14, 2002
    2,997
    St.helens
    +384
