Quantcast
How to choose- Sony or Panasonic?
D
Dave Murray
Hi List
Just had a very bad experience with a Canon MV350i. Picture quality was ok - but the buzz of the motor drove me crazy.
So second time around I want to make the right choice - read lots of reviews and have two left:
Panasonic NV-GX7b
Sony TVR 25e
What video gives the Sony rave reviews but I have read it's indoor performance is not great, and as the camera is for recording family events this sounds like quite a drawback.
I can find as much info about the Panasonic but its small size and built in light makes it very attractive.
So I am sitting here on Saturday morning ready to order my camera on Monday and just can't decide - after the disappointment of the Canon, of which I read some very good reviews, I am anxious to get the next camera right.
Can anyone out there convince of one over the other - I guess they are both good cams - but need to decide on one
Thanks in advance.
Dave
E
eddie95
I've heard a lot of bad comments on the GX7 from people who bought it and took it back. Visit the simply DV forum.
And I believe sony are always the best to go with as they really know what theyre doing. Sony cams always have so much more features than any othermake of cam. But I also hear the sony cam your after bleeds colours quite a lot...ever considered going for the pc101 or the pc8 ?
S
scott69
I bought the GX7 last month from jessops for £728.00 and absolutely love it !!
the picture quality looks great and I really like the controls, which are easy to operate. I considered different cams and found this to be( in my opinion )the best option. I would recommend it.
D
Dave Murray
Thanks Eddie - checked out the forum and found a few negative posts - but also some negative feedback about the 25e low light capability. Not very keen on the vertical models - no reason just prejudice.
Scott - thanks for your reply, a strong recommendation makes my decision easier - you said you looked at other cams and found this one the best - what eventually swayed you?
Dave
S
scott69
I was down to the same two cams you are looking at, as i was trying to stay below £750 ish.
both these cams are above average for the price and both have quality lenses ( sony-carl zeiss / GX7-leica dicomar).
I would advise you to go to a shop and look, feel and play with each cam to see which you prefer. Happy shopping...
