Does anyone know? Old EPG was simple, but I cant find it anywhere on the new EPG.
robfosters Established Member Nov 22, 2010 #1 Does anyone know? Old EPG was simple, but I cant find it anywhere on the new EPG.
robfosters Established Member Nov 22, 2010 #3 Cheers mate. If it says connected, does that mean its definitely working or just there is a line connected to the box? I used to like the test you could do.
S Stevenage Neil Distinguished Member Nov 22, 2010 #4 robfosters said: I used to like the test you could do. Click to expand... Try accessing your account - this will tell you if the line is working or not.
D davemurgatroyd2 Distinguished Member Nov 23, 2010 #5 You can also do a "new installation" from the hidden installers menu.
logiciel Moderator Nov 23, 2010 #6 Or simply try to use it for something like checking the price of a box-office film.
