How to Check how may hours on Pioneer PDP 428xd?
T
theEdge1974
Hiya please could someone let me know how I check how many hours ive watched on my plasma so far I cant see anything in the manual about this any help would be great
thanks
overall a great set my 1st plasma
Freeview excellent
( my aerial is over 30 years old as well )
Standard DVDs via 8 year old Sony dvd player running through scart EXCELLENT
( will upgrade to a new DVD when HD format comes to some compromise)
brad
thanks
Freeview excellent
Hi Edge,
Have a look here mate for how to enter the service menu to get the amount of hours run:cool::cool:
http://www.avforums.com/forums/showthread.php?t=544315
Also give the D65 settings a go as well as these are very good:thumbsup::thumbsup:
T
theEdge1974
Hi Brad
Sorry for being extremely thick but how do access the Service menu? I know there the home menu option is it from there i can access it ?
still confused!!!!
=adrian=
************DO NOT PLAY WITH THIS UNLESS YOU KNOW WHAT YOU ARE DOING**************
The get into the service menu do the following..
Enter the Service Menu
Start with the plasma turned OFF
Make sure you point the remote directly at the IR sensor in the tv
Press the i button (directly below 9) on the remote (just press, do not hold)
Wait 3 seconds
Press LEFT, UP, LEFT, RIGHT then POWER
If done correctly, the plasma turns on and the INFORMATION page is displayed, will change 3 times on its own quickly.
the hours meter is on page 5, scroll down with arrow,
to switch off service menu simply hit HOME MENU button on your remote.
http://www.avforums.com/forums/showpost.php?p=5035681&postcount=1
T
theEdge1974
Sorry mate still no luck
after doing the Left UP LEFT RIGHT part where is the power on the control i assume if the plasma is gonna turn on is this the button top of the control the orange one? still nothing happening aaraaaarrrrrgh!!!!!
help!!!!
thanks mate
=adrian=
Try it that way:
Start with TV switched ON
then hit POWER button to put it into STAND-BY mode and don't wait, hit i+ button straight away,
then wait 3 sec. and hit LEFT, UP, LEFT, RIGHT and Power.
It should work, keep trying
