How to change speakers in a BMW
DodgeTheViper
If anyone can help me with this it would be most appreciated.
I want to change front and rear parcel shelf speakers in a 2002 3 series coupe.
I want to put a set of components in the front
I've had the door cards off but need help with the speaker connectors, and tweeter. Do i cut the stock speaker connectors off and reconnect to my new crossover, then just cable them from there. Or is it best to recable the whole lot as i'll be changing the HU at some point anyway. Then i'll probably amp the fronts and add a sub.
I quite fancy a stealth sub from the likes of autoaccoustics. Other than that i'll add subs to the underside of the parcel shelf and do away with the rear speakers
