HOW to? CAT5 as Speaker cable?
Discussion in 'Cables & Switches' started by eastman3000, Mar 15, 2006.
  1. eastman3000
    eastman3000
    Mar 14, 2006
    447
    +19
    Hi Guys,
    I have a stereo setup at moment. whats the best way of using CAT5 to connect it up? Is it just a single cable per terminal (+ -)?
    Advice appreciated.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Link in my signature for a basic version. HTH
  3. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    I was just looking for that link... saved me loads of frustration!
  4. Jack Dotson
    Jack Dotson
    But, how does it sound?
  5. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Like any other decent speaker cable except it cost a fraction of what hifi dealers sell speaker cable for.:thumbsup:
  6. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
  7. eastman3000
    eastman3000
    Mar 14, 2006
    447
    +19
    Excellent stuff guys. Thanks for the info.
  8. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    More here :
    There is a good visual description in here how to “colour code” the CAT5 cables, use in tandem with KSs site above. Also read all the threads in this site about it, there are a few thorugh the years.
    http://evildonut.34sp.com/diy/FFRC.html
  9. sponnie
    sponnie
    Jul 3, 2005
    78
    What about Cat 6?
    I was just looking at Maplins and it says Cat 6 is the new standard in networking and it's backwards compatible with Cat 5.
    It looks similar but the white cables are paired with the coloured ones.
    It's cheaper though @ 33p
  10. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    CAT6 has exactly the same CSA amount of copper as CAT5 IIRC. It can be used as speaker cable too. In fact just checking Maplins for their CAT5 (code VB20W) that is listed as 79p/metre. So I would use the 33p stuff myself, Ive made various differing types of CAT5 cables and they all sound exactly the same.
    As for the conductors ie striped and coloured ones, you separate them all anyway even with CAT5 the config is the same as your link to strips the ends, then you “combine” all striped and all colours, this becomes your “colour code” mode, becomes impossible to cross wire from speaker terminal to amp binding posts. See links to the Evildonut FFRC page.
  11. Crisp_Rapper
    Crisp_Rapper
    Jan 5, 2006
    263
    Leeds
    +8
    just the question i was gonna ask... right, gonna get me some cat5 later :smashin:
