How to cancel an Auto Change setting?
Discussion in 'Cable TV & Virgin Media TV' started by CapricaMan, May 2, 2007.
  1. CapricaMan
    CapricaMan
    May 18, 2006
    105
    Reading
    +3
    Good Morning all,
    When I go back into the EPG to cancel the Auto Change setting on a programme, I don't get the options window, only a window telling me the reminder was not set due to an earlier setting. Am I missing something?
    Also, while I'm here....a green light has appeared above the middle number of the channel indicator on the front of the box. Can anyone tell me what it is?
    I'll check back later.....
  2. CapricaMan
    CapricaMan
    May 18, 2006
    105
    Reading
    +3
    It's OK, I've just found the "Your Reminders" option in the "More" option of the "TV Guide". A mere press of the OK button on a highlighted programme deletes it.
    Now, if I can just figure out that green light. I think I first noticed it after dropping the remote.....
