How to calibrate a Toshiba PF1?
Discussion in 'Home Cinema Buying & Building' started by barebones, Mar 20, 2005.
  1. barebones
    barebones
    Mar 20, 2005
    41
    Manchester
    Hello,
    I own a Toshiba 36ZP18.
    What would be the best dvd to use to improve my picture quality (via the service menu)?
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    Use Avia for NTSC, and DVE for PAL.
    There's a basic 'how to' for digital projectors in thh DLP/LCD forum and that might help.
    It's only for basic calibration and you don't need to enter the service menu for those adjustments.
    Gary.
  3. barebones
    barebones
    Mar 20, 2005
    41
    Manchester
    What if I had accidently changed some of the service menu settings without noting down the originals, and wanted to get them back to their best? How could I do it myself or should I just call an engineer? If so would it have to be a toshiba engineer?
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    If the image was noticably inferior then you would need to get in someone who knows how to get things back to normal. I would think any good tv engineer should have an idea of what to do though.
  5. barebones
    barebones
    Mar 20, 2005
    41
    Manchester
    Cheers mate
    But would the engineer be using a calibration dvd? I only messed up two or three of the 20 or so parameters, and I could probably fix it myself (the picture now looks a little less sharp than it did).
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    I've no idea to be honest, but maybe they use internal test patterns or just the service menu. If you don't have a dvd player, they can only rely on their eye or maybe a simulator, but Joe Public probably isn't that bothered for them to bother, if you see what I mean.
    Using a test DVD like Avia or DVE might help if you know what service menu options will improve the sharpness, There are patterns for doing just that on there.
    Gary.
