How to cable low-cost devices into plasma challenge!
Discussion in 'Cables & Switches' started by keppy, Nov 29, 2004.
  1. keppy
    keppy
    Here's the equipment i'm trying to connect for a friend:
    o Sky box with SCART output
    o VCR with SCART output
    o Playstation 2 with out-of-the-box cable (composite or SCART video o adaptor without pin-8 switching)
    o XBox with out-of-the-box cable (composite or SCART video adaptor without pin-8 switching)
    o Sony DAV-S400 DVD player and surround system - has a composite video output for the DVD signal
    This will all be going into an unpurchased Panasonic TH-42PW7B screen (so not selected connection boards yet).
    Question is, minimising cable runs to the plasma (all other kit together), what's the optimum cabling? I've tried using a SCART switcher (one that uses pin 8) and this obviously doesn't work with the consoles or the DVD signal...
    Cheers,
    Keith
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    buy proper scart cables RGB for the consoles and Quintro will work without but for gods sake man its a PW7 £2o on a PS2 cable isnt gonna break the bank.... and replace old and crappy DAV-400 Panny SCHT25R does the job nicely...........
