New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
I had an old version of Nero Burning ROM, which used to let you copy direct from one CD to another if you had two drives.
Do you need to copy direct from CD to CD though?
I always recommend copying the CD onto your hard drive (by using software to create an 'image' of the CD, or even just by copying the data off it manually) and then burning to another CD from there.
