How To Build your Own Freeview Box.....
Discussion in 'Freeview & YouView' started by waynewickenden, Feb 22, 2005.
  1. waynewickenden
    waynewickenden
    .........Has Anyone got any Good ideas?
    I was just thinking the other day that companies i.e Nokia, Daewoo,Goodmans, all recieve huge ammounts of profits each day by people purchasing their freeview boxes, but what if WE knew how to build one? That would surely give those companies something to think about, Don't you agree? Besides, The companies no doubt Mass produce their Boxes as cheaply as possible, therefore showing little consideration for the buyers.
    It can obviously be done, so where is a better place than "Digital Spy" to get some good advice from. Someone on these forums must surely know how to do it, so any replies would be very much appreaciated, and not just by me, but by others aswell!
    Before Posting: If the above is illegal I sincerely appologise on my behalf and wouldn't condone it in any way, shape or form.
  2. GaryB
    GaryB
    Nov 12, 2002
    5,396
    St Albans
    +1,307
    You're very much mistaken if you think that manufacturers make huge profits on STBs. The margins are wafer thin. With boxes available for £30 and R&D costs well into hundreds of thousands I think you're wasting your time.
    PS This is AV Forums, not Digital Spy.
  3. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    :rolleyes:
  4. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    lynx, how much are you paying wayne to start all these threads? ;)
  5. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    It could be done but wouldn't be worth the effort.
    For info look up setpal and Novapal in Google.
    You need a DVB complaint COFDM tuner/demodulator chipset reference design. The whole design and firmware can be licenced - which is what many of the STB manufacturers did.
    You would have trouble getting hold of the key ICs though (unless you work for Nokia, Echostar, Daewoo , Sagem etc.); you would also have trouble getting a licence for the necessary IP (intellectual property).
    I work for a USA-based IC manufacturer (technical/applications support for users of our ICs) so I do know what's involved - even though we don't make these ICs.
    When the original digital terrestrial STBs came on the market at over 100 quid DIY might have seemed worthwhile ; however at that time there were only a couple of manufacturers of the key tuner chips needed and so the cost of the chips was much higher.
    Competiton and large volumes eroded the price of such ICs and so the market price of the STBs then followed suit.
    Chris Muriel, Manchester.
  6. Flimber
    Flimber
    Sep 22, 2002
    13,723
    Yorkshire
    +4,484
    Maybe a kit has been published in an amateur electronics mag or summat ?
    Mike.
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    I doubt it - unless they have made arrangements to purchase the necessary IP and the core ICs required.
    I am , however, prepared to be proved wrong if anyone finds anything like this.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    chris do you know awt about the BBC designed Semi-pro DVB boards that were used to test the viability and technical capabilities of FV (may have been crown castle) i saw a site with info just after ITVdigital collapsed...but cant find it I would love to find a source for SDI DVB reciver and the BBC board was just that......
