how to build a hush box for projectors?
Discussion in 'Home Cinema Building DIY' started by junkster443, Jan 12, 2005.
  1. junkster443
    junkster443
    anyone have a guide on that im a total noob when it comes to building boxes any guide with pictures and explanations?
    thanks
  2. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    I'd be most interested in this too as my PJ likes making itself heard
  3. junkster443
    junkster443
    you have the 7200 i have that too! its very annoying!
  4. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    'tis a shame about the noise as it is a beautiful piece of kit in all other respects IMHO particularly for the £2k I paid. I initially had the 5700 but we had mis-calculated so it wasn't quite able to fill the 7' screen hence the change to a 7200 which fitted the bill perfectly and is of course higher res (subject to what is connected of course).
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,119
    +1,647
    Wouldn't it have to be a (heat) conductive substance that also absorbed sound.
    A big metal box with fins and holes cut out in the appropriate place would do, but i can't think of an easy substance that does both.
    Most noise absorbing materials also insulate heat which is very undesirable for a projector in a box.
    Maybe two metal boxes, one inside of another connected via a heat pipe and foam in between would do. So the inner box absorbs the heat and transfers it to the out box and the foam inbetween would absorb any sound. But you still need holes for the connections and light to get through.
    Could use a rubber cealent(spelling) if all the cables where connected already then wraped in another piece of plastic. So all the connection cables go into a single wraped cable which is then sealed using rubber. For the front use a very clean piece of perspects or glass which is also held in place with rubber (to keep the sound from escaping).
    This is probably a bit over kill but would completely silence the projector, although access would be very dificult.
  6. junkster443
    junkster443
    [​IMG]
    how do you make a box like that one?
    i could buy that box but it would cost me too much money!
  7. pragmatic
    pragmatic
    Nov 9, 2004
    12,119
    +1,647
    Would that at all stop noise, it's even got a wirrrr'wy fan on the back and side.
  8. junkster443
    junkster443
    yes it has anti noise and silent materia its special and the fans are ultra quite!
    noisedamping foam and stuff
