How to bridge two Mission 75c speaker connections?
Discussion in 'Home Cinema Speakers' started by Vipen, Aug 5, 2005.
  1. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    Hi all, i have a pairt of Mission 753s (i just can't let them go) and have finally made a move on a 75c centre.
    On the 753s the connectors are bridged with a little gold plated (gold?) stick of metal on each, two per side.
    The 75c i have has two pairs of connectors (hi and low) but i don't have a magic stick to bridge it with.
    Any suggestions what i can obtain from the high street to bridge these connectors or do/should i contact mission for these gold metal pins?
    btw, does anyone know what the matching rears were for this set-up?
  2. Troon
    Troon
    Apr 28, 2005
    151
    Use a very short length of speaker cable.
  3. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    aah, ok, thanks. is the conductivity dependant on the quality of the cable and should i still look to get some of these gold plated (gold??) pins from mission?
  4. AMc
    AMc
    Nov 20, 2000
    5,720
    Near Norwich
    +2,260
    If you use a short length of the same cable you're using to connect to the amp then it will be undetectable.
  5. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    excellent, thanks very much
