Geege
I'm thinking of boarding my loft for general storage and I'm looking for advice on how to best approach the task. I've read up quite a bit and I think I have an idea of what I should do.
I'm thinking of screwing timber at 90 degrees to the existing joists to raise the floor a little to allow clearance. I do not want to cut grooves into the existing joists as I understand this may weaken them. What should I use, treated timber, stud partition timber?
Then I'm thinking of laying floor boards on top of that, thinking about moisture resistant chipboard 22mm thick (green board) Tongue & groove, for example what Wickes sell.
There seems to be sufficient loft insulation already, but I guess I could top it up a bit.
Any suggestions as what I should consider?
- I have a Trussed Rafter type loft in a new build terraced house (2004).
- My loft hatch is a standard uPVC which is about 620mm x 520mm in size.
- The current joists measure about 35mm thick x 96mm tall and are spaced about 560mm apart.
- I have some plumbing in the loft (not much, my control unit just for my Triton Digital Shower) and three up-lighters from the bathroom.
- I have some electrical cables, sky satellite cable and mains cable that runs over some joists.
