how to analyse the effects of ffdshow
Discussion in 'Desktop & Laptop Computers Forum' started by Kaz, Feb 25, 2005.
  1. Kaz
    Kaz
    on a bit of a mission to button down a set-up (that I believe in and won't have a hankering to tweak) before leaving well alone....
    So I'm trying to prove to myself and anyone else who's daft enough to listen that ffdshow is helping.
    I'm using TT1.5's screen capture and comparing with and withouts. I've a recollection of some mouse over pictures on the TT forums where yoda looked obviouslsy clearer with ffdshow doin some stuff. But try as I might, my bitmaps are pretty much identical.
    Is VMR and overlay "stuff" being bypassed in the method of screen capture and ruining my tests?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I've no idea how the screen grab feature in TT works but it may very well be taken at the point when the image has been decoded and before processing.
    This is the article you're thinking of, not sure if it details in there how the screen-shots were taken.
  3. Kaz
    Kaz
    that's the one! quite compelling isn't it?
    It's obvious really, TT passes it onto ffdshow which then sends it to the graphics card to render.
    indeed, why would a screen capture feature in TT have access to the image that gets rendered? doh!
    so what now PrtScr? I'll have a look for another app, the type PC mags do for showing the differences between graphics cards and settings for games seems a good place to start.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I really have no idea how those shots were taken, it may also differ between VMR and Overlay.
  5. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    You can apply your settings to the right hand side of the image only. That way you can see the original playing on the left and the processed on the right. Have you tried this?
  6. Kaz
    Kaz
    that tick box is always greyed out for me?
  7. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    I have seen that but never tried it, i think i will have to have a play around with that, infact i am happy with the picture at the mo so maybe it is not such a good idea :)
  8. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
    Can anyone tell me what option I need to select to do this? Is it under video?
  9. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    I have seen the only right half box under postproccessing. It is gryed out under some screens but it should be available under that screen
  10. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
    Ta. Found it. Seems like the effect of ffdshow on my dvd's are very subtle but then I'm viewing them on a 17" LCD not a whizz bang plasma or 6ft projector (which I expect is where the real benefits can be seen).
