How tightly can you fit an LCD TV into a recess?
richard plumb
I have an ikea best a TV unit which has an enclosed frame (surrounded by wall units so no option to expand). Internal measurements are 114cm wide, 80cm Hugh and 31cm deep.
I currently have a 40" LCD TV in there, but was wondering if I can squeeze a 46" in there. One is 108.5cm wide and 68cm high with the pedestal stand. (the other is 112.4cm wide so probably a non-starter). Current TV is 98cm wide x 68cm high, so the difference is only 10cm on the width
A couple of issues spring to mind. Firstly, access to the back. I think I'd manage, either by using an extendable mount, or just sliding the TV forward onto a box or something.
Main issue is ventilation. Manuals usually say to leave 10-15cm at the sides, and 30cm above. I already don't have that clearance with my 40", and it'd be tighter still with a 46". As it's open fronted, will heat just vent out into the room? Can I cut holes in the back panel to help it vent out the back? (the units are freestanding so there is open space behind)
