How tight can a Viera TH-37PX70 fit to wall
Discussion in 'Plasma TVs Forum' started by Barnes, Jan 25, 2008.
  1. Barnes
    Barnes
    Aug 29, 2006
    139
    +3
    Called John Lewis and Panny is in stock now. I'll order tomorrow.Hopefully worth the wait.
    I wall mounted my Hitachi 42PD9700 on a bracket from AV4home which held it about 20mm from the wall (ordered before the telly arrived).
    However when the telly arrived the scarts pointed out 90 degrees from the back of the unit. The scarts were going to be chased into the wall so it wasn't a problem as the scart body connection was protruding into the wall cavity on the plaster board dot and dab wall. If it had been a solid wall the bottom of the telly would have been held off the wall by the scart cables.
    The wall I'm mounting the Panny on is solid,no dot & dab. If I buy a tight fitting bracket will the scarts protrude past the back of the telly and come into contact with the wall. I'm not keen on getting the bolster chisel out and whacking the wall to bits but I don't want it looking pants by being miles off the wall.
    Cheers.
  2. Bobred
    Bobred
    Nov 15, 2007
    30
    There are some 90% scart adaptors that can help aleviate this problem.
  3. Barnes
    Barnes
    Aug 29, 2006
    139
    +3
    Cheers,
    Any idea where to source the adapters?
