HOW THE HELL do you...
T
testingtimes
...change a folders properties inb Windows XP.
This has been driving my NUTS for the last 40 minutes. I could do it in Windows 98, but in Windows XP I've not got any idea.
If I've not explained this clearly I'll embellish.
The purpose is to add to a web folder on a server a piece of script which will restrict access to people from my company only. I've got that script, but I can't open up the folders giblets and innards to insert the script and then save it up again.
I remember messing about in windows 98 before where I copied the code from the Programmes and Windows folders on the C:/ drive (the ones that flashed up the warning message 'editing content in this folder may cause damages' etc) so that when a certain folder in My Documents was opend it said something along the lines of 'My folder Keep Out!'.
If you like, when you view the "source" of a web page (view/source) I want to do the same with a folder in Windows XP.
BUT I CAN'T DO IT!
ARGH!
I'm going out for a fag now - hopefuly when I return someone would of been kind enough to tell me...
Dan L
You need to change security permissions on the folder?
T
testingtimes
Thanks for the response, but I don't think that's what I'm after - that is if you're refereing to just right clicking the folder and adjusting the security settings from within properties.
The restrictions I wish to impose are more specific than just starting blanket bars on reading or writing to the folder.
Any more suggestions?
Dan L
So...you want to set security permissions to a web-accessible folder to certain people, where they can enter a username & password to get to it?
Just guessing really, I'm not 100% sure what you are after tbh.
