How the heck do you get the wrist strap on?
mark88
Is this some kind of puzzle, I cannot for the life of me get my white wrist strap to fit on my PSP. I know you're supposed to loop it through itself but it sjust won't do it, even when I try doing it without the PSP. The string will not fit over the rivetted part of the strap.
Am I missing something?
chrislad
You have a small loop and the main strap. The small loop goes through the section on the lower left of the PSP. Then you put the strap through the small loop. It's not that hard :)
mark88
Yes, I know what the idea is. I'm saying the loop is too small for the strap to fit through even without the PSP itself involved.
DLPMaybe
put your hand through the large hole. :rotfl:
Don't think you're missing anything. Maybe your thread bit is shorter than normal.
chrislad
My loop is big enough for me to put two of my fingers in it. *shrugs*
Email Sony for a replacement.
DancingJester
It took me awhile to get it attached, one side of the wide white part has a flap, if you try to feed that through the loop it gets well and truely stuck, if that makes sense and/or helps any ...
Also I found I was being far to gentle and with a bit of 'persuasion' it will go on in the end!
emporer
its a tight fit but getting the thing off is a different matter, it took me ages and was nearing the point of cutting it off as it just looked so gay
S
smallmanongn
Yeah,you think putting on is fun,try getting it off again,like emporer said,its nearly impossible!
