How should I connect my iScan
Discussion in 'Plasma TVs Forum' started by SherrifJWPepper, Jul 14, 2003.
  1. SherrifJWPepper
    SherrifJWPepper
    Im conecting it to the pannel using VGA but which of the following options would be the best for conecting my periferals
    VCR - Composite in
    PS2 - S Video in
    they are the easy ones
    1, RGB>YUV on both my freeview and DMR30 to component in on the iScan
    2, RGB>YUV on the DMR30 and plug the freeview box into the RGB passthrough
    3, RGB>YUV on the freeview and S Video for the DMR30
    4, DMR30 and freeview on a scart swicher feeding RGB>YUV
    5, S Video on the DMR30 and plug the freeview box into the RGB passthrough
    I sort of favour option 1 but I have been told by a local dealer to use S Video for the DMR and not to convert it:confused:
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    344
    16
    Option 2 sounds best. I have no idea why S-Video would be recommended over a YUV-converted RGB signal.
