How should I arrange my rear surrounds?
Discussion in 'Home Cinema Speakers' started by steve 111, Oct 19, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Planning to upgrade from 5.1 to 7.1. I currently have my left and right surrounds (MA Bronze BFX) in bi-pole mode level with my seating position.
    My seating position is approx. 4 feet in front of the back wall and I want to mount my centre rears on the wall.
    I've heard that for centre rear channels you are better off going for mono-pole speakers. Is this correct? If so what could I buy to match my Bronze B4s that are wall mountable?
    If this isn't correct I will probably buy another pair of BFXs. If I do how should the 4 surrounds then be arranged, bi-pole, di-pole, or a mix of both?
  2. ab1385
    ab1385
    May 30, 2004
    1,321
    Cardiff
    +74
    In your position I'd probably get a pair of Bronze B2s for the rears, and just buy a normal speaker bracket, and keep the BFXs level with your seating position.
    I really cant remember fully, but I think dipole is best for sides. :)
  3. 337GUS
    337GUS
    Nov 1, 2000
    756
    NE Scotland
    +39
    Monopoles are generally recommended for rears in a 5.1 setup aimed at multichannel music/dvd-a/sacd.
    I have a similar layout to you and have gone dipole sides, level and just above seating position (MA Gsx) and bipole rears, again just above head height (MA Sfx).
    I would suggest MA Bfx dipole sides and another pair of Bfx as bipole rears for 7.1 movies.
    HTH
    Gus
