So.. what can age on speakers.. Timescale.. you cant really give one as there are too many factors at play but.. i can at least show what "can" age .. and where to look / listen atIf buying used speakers instead of new - how old is old?
Would 7 years be a problem?
I have my eye on a pair of KEF Refrence 5s which look pristine, but what can age on a speaker and how long does it take?
I have Celsetion DL4's 1980's still going strong, Mordaunt short MS 3.50 1991 still the best speakers I've heard (my opinion of course and my ears), Davis DK170's 1996 still magic a pumping out rock. Some technics from late 1980's not my cup of tea but still in good working order.If buying used speakers instead of new - how old is old?
I can assure you my spiders, geckos and smoking hasn't affected my speakers one bit, I don't even think my extremely dusty environment has either. Dusty shouldn't be a big problem in the UK as it rains so much.Whats the saying? It isnt the age, its the miles.
Well looked after and in a good environment and not abused or full of spiders, then probably fine.
But a year in a cold damp garage, or a poor environment (smoker, open plan with kitchen in the same area can be bad as people often have at least one smokey moment or just a typical urban dusty environment etc).
Yes, I've been looking closely at the pictures and there is clearly damage to one of the woofers, probably not enough to be audible, but it's a lot of money for a damaged speaker.
They look to have some dents in themThis is probably not going to have an audible effect, but I can't spend £7k on a speaker that looks like this. I would not be able to take my eyes off this.
£7K is about par for Reference 5's in good condition, which this isn't. What you could do is ask KEF what it would cost to replace the damaged drive, then make an offer that takes the repair cost into consideration.This is probably not going to have an audible effect, but I can't spend £7k on a speaker that looks like this. I would not be able to take my eyes off this.
I disagree. Perfect and tumble-free alignment of voice coils is absolutely possible. I have build hundreds of woofers and midrange drivers with my own hands and I have inspected dozens and dozens of customer objections (different brands, there were almost no returns with the units me and my colleagues built). One thing that can cause damage is small metal splinters that went by unnoticed prior to charging the magnet (and that slipped QC). Apart from that in more than 99% of all cases overdriven voice coils have been the reason for failed drive units. Not covered by warranty, of course.What else... the motor assembly.. the voice coils.. every time a cone moves, there may be some scraping as perfect alignment is almost impossible.. over time the insulation on the coils can get worn and then they do not work properly or end up scraping in the basket.
Did the seller have anything to say about it? Looking at the picture it seems unlikely this is just a photographic artefact, but well, just saying ...This is probably not going to have an audible effect, but I can't spend £7k on a speaker that looks like this. I would not be able to take my eyes off this.
