How not to bywire speakers (?)
Discussion in 'Home Cinema Speakers' started by kstandsteve, Apr 10, 2005.
  1. kstandsteve
    kstandsteve
    Apr 4, 2005
    58
    11
    I have bought a pair of fronts with dual connections for bi-wiring. If I choose not to bi-wire do I need to provide short jumpers to the other terminals?
    If so does it matter which terminals I take the main leads to?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    You do indeed need to connect the relevant terminals if you choose not to biwire (I do this with a few short lengths of speaker cable). You need to connect the 2 +ve terminals together and the 2 -ve terminals together, any other way will cause one of the drivers to be out of phase or just prevent your amplifier from working altogether which is a bad thing. :)
  3. kstandsteve
    kstandsteve
    Apr 4, 2005
    58
    11
    Thanks for that. Will do as you say and use a short length of speaker cable.
    Cheers.
