How noisy is your HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by sraper, Feb 14, 2002.
  1. sraper
    sraper
    Aug 7, 2001
    476
    Watford, UK
    +58
    Just curious. It is obvious that a HTPC must be quiet and there is a lot comment here about how to achieve this. however how noisy is it really? Surely everbody here is has an SPL meter, how else do you configure your audio side to match the visuals of your HTPC with projector/plasma :)
    So why not get those meters out and let us know how quiet or noisy it really is :)
  2. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    My analogue meter only goes down to 60db, my PC sure isn't that noisy. High 20s low 30s is probably a realistic noise level to aim for. I don't worry about PC noise that much these days since my projector is about 40db.
  3. sraper
    sraper
    Aug 7, 2001
    476
    Watford, UK
    +58
    bugger your right! I posted the original message during a boring bit at work.
    Now that I am at home I have just dug out my spl and tried it out on my very noisy PC and I can just about get 55db reading on the scale!
  4. Desmo
    Desmo
    Jan 4, 2001
    13,413
    Braintree, Essex.
    +4,760
    Mines as quiet as a quiet thing :)
  5. NickBull
    NickBull
    I have one annoying fan noise, it's a quietpc Athalon CPU fan, quieter than my old one, but still has slight whiring! May also get a slight sound from my Radeon fan, but can't really tell.
    PJ is the main source of noise, but Roland is working on a mod, and I'm building a cabinet to put AV gear and PC in, so soon it should be nice and quiet!
  6. mjn
    mjn
    May 24, 2001
    17,598
    Herts, England
    +4,518
    mines fairly noisy, no idea what db level, as i ain't anything to measure it with....but the main fan is the worst.
  7. Desmo
    Desmo
    Jan 4, 2001
    13,413
    Braintree, Essex.
    +4,760
    My noisiest component is the DVD drive.
    I now rip latest/current/most watched DVD's to hard disk and play them from there.
  8. jrwood
    jrwood
    My HTPC is probably up there with the quietest PC's :), although this is due to the fact I have no fans in the PC (ATI heatskink+heatskinks for the P3-550mhz cpus). No doubt I will have to look into other ways when I want a 1ghz CPU....
  9. mysphyt
    mysphyt
    The CPU fan is the worst offender for me. I've put variable resistors on all the fans, added soundproofing and even built a hushbox. The things still audible during quiet bits.
    The details are Here.
  10. Desmo
    Desmo
    Jan 4, 2001
    13,413
    Braintree, Essex.
    +4,760
    I've just checked your HTPC specs from your site and noticed you're running an Athlon.
    Just go to www.quietpc.com and buy the Flower heatsink kit.
    After that you'll find the PSU will be the noiisiest piece of kit.
    Unless you buy one of their quiet PSU's as well :)
  11. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,727
    2
    167
    Birmingham, UK
    +9,403
    Interesting. How long does that take, then?
    Presumably you don't get any pauses at layer changes, either.
  12. Desmo
    Desmo
    Jan 4, 2001
    13,413
    Braintree, Essex.
    +4,760
    Varies. Normally about 20-30 minutes.
    I just keep about 3-4 of my latest/most popular films on hard disk.
    You can then either put the vob files into a playlist and away you go or, using PowerDVD 4, you can open "the disk" from the hard drive and still use all the menus as normal. Some disks struggle this way. Phantom Menace will not budge past playing the menus, but others I've tried had no problems at all.
