How much would I get for Panasonic TH-32 LXD500 including cabinet
Discussion in 'Panasonic TVs Forum' started by Michael Tonge, Sep 13, 2007.
  1. Michael Tonge
    Michael Tonge
    Apr 25, 2006
    173
    St Albans
    +6
    I am prob gonna sell my 15 month old Panasonic TH32LXD500 32 inch LCD TV, including official Panasonic cabinet, plus the pedestal also.
    I've just checked the hours and they are at 904.
    How much do you reckon it'd be worth?
  2. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    I'm not sure how much you'd get for it, but I suggest that if you're going to try to sell it on the Internet, you use the correct model number (I'm assuming you're in the UK).
    The Panasonic LCDs all start with "TX", not "TH". "TH" is used on the plasma screens. So your TVs model number should be TX-32LXD500. Its helpful to get it right because someone who searched for TX32LXD500 on say, E-Bay, would probably not see your "TH32LXD500" in the results. :)
  3. Michael Tonge
    Michael Tonge
    Apr 25, 2006
    173
    St Albans
    +6
    Cheers! Yeah it is defo the TX32 LXD500, will make sure I put it on right.
    I'll stick it on ebay and see how I go...
