How much to spend on Component cable for new HD box to 32" LCD?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rolfee, Sep 5, 2007.
  1. rolfee
    rolfee
    Apr 2, 2006
    58
    Bit of advice please, just plummeted for HD box from sky due this Monday. I have a Panasonic TX-32LXD500 and as my PC already utilises the HDMI connection into the tv (it is my media hub DVD's, HD/SD material), I will be using the component for HD box.
    What do you feel would be a reasonable amount to spend on the cable to get the best quality? Has anyone got similar set up experiences or can advise if i should rethink inbound connections?
    Thanks all...
  2. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    £30?
    Has that LCD got VGA in? I'd consider that as an alternative for the PC
  3. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    Have to agree with Choddo, try VGA, if set up right it should look just as good as HDMI.
  4. rolfee
    rolfee
    Apr 2, 2006
    58
    Thanks that is roughly what i was thinking for cost.
    LCD has a VGA in so this is an option. However i thought VGA is analogue hence you loose some quality on switching. However i guess this is debatable if you would notice it on a 32".
    Do you think the HDMI Vs compenent on HD box to LCD will be noticable,
    I guess I may be doing some testing :)
  5. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Yeah I think it's very dependent on the components in the TV. VGA is a very high quality analogue signal so I'd say, in theory VGA and HDMI is a better all round option than component and DVI, but only you can really decide. Just make sure the component cable isn't in a non-resealable pack ;)
  6. rolfee
    rolfee
    Apr 2, 2006
    58
    Hi Choddo,
    good point, a trip to Seven Oaks will be made at weekend!!
    I'll let you know my findings early next week.
    cheers for the help.
  7. 499520
    499520
    May 22, 2007
    88
    +19
  8. rolfee
    rolfee
    Apr 2, 2006
    58
    could not get a comparable pic with VGA no matter how much tweaking i did.
    So to fix i just accelerated my amp replacement and got a Sony strda1200 with the 2 hdmi's inputs (credit card is battered now, quiet few months i think).
    Now impressed with pic and some impressive tweaking ability since my dear old Yamaha DSP-A5.
  9. Martin J.
    Martin J.
    Dec 19, 2006
    1,406
    +175
