How much to bung the installer
Discussion in 'Satellite TV, Sky TV & FreeSat' started by camBB, Feb 4, 2009.
  1. camBB
    camBB
    Sep 23, 2004
    211
    +8
    Getting HD installed on Monday and was wondering on how much to bung the engineer to install extra cabling so i can use the RF port.
    It'll go from downstairs to upstairs on the outside wall.
  2. scarey
    scarey
    Feb 27, 2007
    249
    swindon
    +22
    i would expect at least £20...
  3. Anoraknophobia
    Anoraknophobia
    Jan 13, 2009
    85
    11
    London
    +3
    Just offer to buy him a drink.;)
  4. Chadford
    Chadford
    Mar 5, 2006
    5,994
    LS6
    +2,529
    Both good ideas, let us know how you get on. :)
  5. DUVET
    DUVET
    Jul 5, 2006
    295
    need to bung the installer myself.
    but first.
    getting sky hd in due course, only have a nomal box at the min, so he will need to add an extra coax cable for the hd box, but if i run a cable from my bedroom to the dish, will he wire it up for me ? does he need extra equipment on the dish to add a second box ?
    I'll most certainly give him a few £'s !
  6. eric pisch
    eric pisch
    Dec 28, 2006
    7,501
    +754
    If hes polite and does a tidy job and makes an effort to do it all properly £20
    if hes a loud mouth chav who chucks it in as fast as possible nowt
  7. SkyBloke77
    SkyBloke77
    Sep 17, 2008
    110
    Midlands
    +13
    It will also depend on much work he has for the day, he may not have the time to do it that day.
    As for the poster who wants to have a another feed into their upstairs room and is going to run it theirselves, then most engineers will connect it to the dish for you.
  8. TrIggA
    TrIggA
    Dec 28, 2008
    44
    9
    How do you mean by this?
    Cos atm we are have redecoration... but we jsut ffinished a room (both ground floor receptions - back and from)
    We want the cable to satellite in the front room - which wil lstart its renovation in about a months time..
    we're moving the TV to the back room - which already has a cable going up to the roof- so all we need to ask is to conenct it to the satellite?
    is it possible to have more than one feed?
    and is it a different cable - because we already have a connected socket to an empty cable..
    please please clarify xD:confused:
  9. jdp1962
    jdp1962
    May 31, 2007
    409
    +24
    A bacon sarnie can often buy a lot of goodwill.
  10. blackpants
    blackpants
    Mar 9, 2007
    490
    +19
    Cup of tea and choc biscuits was enough for mine back in August!
  11. clual
    clual
    Oct 16, 2006
    475
    28
    +32
    Offer him what you would be happy to except or offer him what you feel the job is worth remembering that he has a living to make.
  12. bladedripper
    bladedripper
    Nov 26, 2007
    5,072
    Birmingham
    +1,527
    How about doing it your self,theres nothing to it and you will probably do a better job and get gold connectors as i did,the lot cost me a tenner from maplins.:smashin:
  13. camBB
    camBB
    Sep 23, 2004
    211
    +8
    Well the guy just finished and was too busy to install the extra cable.
    I even offered him £20!!!
  14. Chadford
    Chadford
    Mar 5, 2006
    5,994
    LS6
    +2,529
    Good try!
    ...absolutely and if you go the DIY route (couple of tips)...
    1) Drill inside to outside slightly down-wards from horizontal as rain doesn't go uphill well without a lots of persuasion.
    2) At the bottom of the cable run where the cable goes into the house run it say 5cm to one side of the hole then 5cm below the hole then backup up (i.e. it has a little saggy loop below the hole). This means that all the rain will run down the cable and drip off the loop at the bottom (not into the hole). This helps as well.
    If you're not a DIY person, I'm sure you must know someone with a drill who likes beer. :thumbsup:
  15. GasDad
    GasDad
    Remembered (1964-2012)
    Mar 28, 2006
    5,407
    Bristol
    +758
    All good tips above,
    3) If your walls are filled with random stone and rubble, once your have drilled through - don't remove the drill bit, get someone to feed the cable in as you slowly remove the bit - this will hopefully stop rubbish falling down inside the wall and blocking your new hole.
  16. Chadford
    Chadford
    Mar 5, 2006
    5,994
    LS6
    +2,529
    Excellent - I'll remember that one. :thumbsup:
  17. GasDad
    GasDad
    Mar 28, 2006
    5,407
    Bristol
    +758
    Unfortunately it isn't 100% - it has worked 5 times out of 6 in our house :smashin: We live in a victorian house built from random stone.
    The 100% way to do it is to drill a slightly oversize hole, leave the bit in situ, remove the drill, then knock the bit out from the other side using a piece of plastic pipe the same diameter as the bit. Cut the pipe of flush and feed the cable through that.
  18. Chadford
    Chadford
    Mar 5, 2006
    5,994
    LS6
    +2,529
    Yes, that does seem a better and more reliable method. :smashin:
  19. Fejinwales
    Fejinwales
    Feb 9, 2009
    184
    Rhondda, South Wales
    +16
    Friend of mine had his HD installed January 16th, he wanted to move his Sky+ box upstairs, run a cable etc...the guy charged him £25 for doing it.
    He was a contractor, not a Sky engineer in a Sky van. Hope this helps,
