How much should my dish move?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cerebros, Apr 8, 2005.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,187
    38
    Leicester
    +11
    As per the title...
    It's been a bit windy today and when I was outside just now I noticed a quite perceptible wobble at the LNB end as the wind caught the dish - probably half a centimetre at least.
    Now I know the dishes aren't the most aerodynamic objects, but should there be much movement when caught by moderately strong winds, or should they be rock solid barring a gale?
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    mine is rock solid in a gale
  3. shelfsider
    shelfsider
    Mar 29, 2005
    74
    11
    +6
    Mine wobbles a bit but then its stuck up on a 6 foot pole to get over the roof
  4. cerebros
    cerebros
    Dec 27, 2002
    1,187
    38
    Leicester
    +11
    hmm.. well mine's about 3 metres off the ground bolted to a wall of the house. Might have to see about getting it tightened
