How much should a plasma wall mount installation cost?
Discussion in 'Home Cinema Buying & Building' started by kamaran, Aug 31, 2005.
  1. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    I want my plasma mounted above a false fireplace.
    The wall is 75% hollow (plasterboard), 25% brick. From this point I want the cabling chased about 1 metre through solid brick where I will have my A/V rack. I plan to buy a pioneer with media box, so the cabling should consist of only a VGA lead and power lead.
    Any idea what type of cost is reasonable for this type of job? I would want someone to do all the re-plastering/decorating after the install.
    Something similar to this for the look:
    [​IMG]
  2. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Lots of views and no replies :(
    I have been ringing around for quotes today and they have varied between £250 - £1000
  3. ALSC123
    ALSC123
    You are looking at 350 all you do then is paint over plaster mark
  4. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Cheers, whats that price based on? Personal Experience/your company price?
  5. ALSC123
    ALSC123
    What area are you in I might Know somebody you can trust
  6. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    West London (near Twickenham)
  7. ALSC123
    ALSC123
    A little to South for me to know someone sorry although Im sure someone will be able to help
  8. aarons
    aarons
    what sort of redecoration is involved ie paper or paint
  9. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    some paint - ill put up a picture of the setup I want
  10. exdisti-mark
    exdisti-mark
    I know some installers based near epsom - not a million miles away.
    They do installs for some large pub chains etc.
    drop me a pm if you want and I will get you contact details.
    They will come and do a free survey first and price is £300 - unless complications arise on survey.
    cheers
    Mark
  11. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    I have had a number of quotes now, the one I am happiest with (not the cheapest) but standard of work/knowledge seems excellent is from a company called bluestreamav - http://www.bluestreamav.co.uk/
    I plan to schedule the install soon and will post pics!
  12. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Bluestream are very good guys. You'll be fine with them.
    I've heard of some £100-£200 installs, but I have then revisited the site a while later on other business to find silver trunking run up walls, or cables dangling and tucked away behind other furniture. £350-£550 will get you a proper hang and chase of all cables, a fused spur run from the mains ring up to behind the plasma, and enough time spare to re-route your Sky TV feed and telephone point to whereever in the room your kit is going to end up (which needn't necessarily be near the plasma for added effect). All you will be left with is sanded down filler where the chase(s) were cut for you to slap a quick layer of paint over in a couple days time. Wallpaper a little trickier, but there are always ways.
  13. davee
    davee
    Jun 15, 2004
    706
    twickenham
    +58
    Just make sure that all the sanding down and painting is done before you mount the plasma. The dust hangs in the air for days :rolleyes:
  14. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Cheers, davee. By the way I live in Twickenham too (Whitton actually) did you get a custom install, who did you go with?
  15. wooke01
    wooke01
    Can you tell me who you used? we live in hampton and are looking to do the smae thing. Was hoping to hang tv on wall and poke the cables through back of the tv into a cupboard which is behind the wall we want to hang tv on. We would then put all the cables and dvd etc in the cupboard to hide the cables.
    Thx
  16. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    I used www.bluestreamav.co.uk - excellent job, I can 100% recommend them. Several of my friends/relatives have now had a plasma install done too and are really happy with the results.
    See my signature for my install pics.
    If you do give bluestream a call, please mention you got the details from Kamaran via the avforums.
    Hope that helps.
  17. 381stuart
    381stuart
    Feb 5, 2007
    5
    3
    Try these guys, they are local to you, friendly and professional too!
    www.hdav.co.uk
