P
Phil Durkin
Just bought componants for a PC which are
AS Rock K7VM4 Mother board (built in LAN)
AMD Athlon 2800 XP
Seagate Barracuda 120Gb Hard Drive 7200 rpm
Radeon 9200se (fanless)
Asus CD-RW Drive
I am wondering what wattage the PSU will need to be?
Is there a magic formula or is it suck it and see?
I will put a DVD Rom in and later another 120GB hard drive and that will be it.
The PSU will have to be VERY quite, as they do tend to hack you off when they whine away so it will be a Silenx either 300W or 400W. From the research i have done on the net they are the quitest or are there any other worth considering?
Any advice would be greatly recieved.
Cheers Phil
AMD Athlon 2800 XP
Asus CD-RW Drive
Cheers Phil
