Quantcast
How much power does a tv use if on stand by?
finlab
Bought an IDTV (sony 28dl10) and stuck a tape on to tape something. Didnt realise that tv would need to be on stand by to tape digital channels so taped a blank screen for 3 hrs.
If I'm heading off on hols and want to tape something this means the tv could be on stand by for 2 weeks (not something I would do normally). How much power does this use?
GrahamC
I think the old standard was 5w/hr and the new standard is less than 1w/hr but around 24hrs for the same cost as a light bulb for 1hr. :rolleyes:
Daftboy
Minimal I would guess. It should say in the manual, but anything from 0.2w to 1.0w.
TV Headache
IDTVs are great but they can be frustrating to tape from. I would strongly recommend buying a DTT PVR like the Humax if you don't want to come back from your holidays dissappointed by blank tape.
bonzobanana
I'm not 100% sure how the digital tuner works in these sets but if the digital tuner is still working in standby then standby mode is going to be something like 10-20 watts isn't it? I mean digital tuners do take a reasonable amount of power. Then again perhaps the vcr initialises the digital tuner into operation somehow. I must admit I assumed a IDTV's tuner only operated when the set was actually on.
finlab
I have to set the tv's timer and the vcr so it's on normal standby most of the time then the stand by led flashes when the digital tuner is on.
