How much overscan is 'normal'?
Discussion in 'Televisions' started by John Jennings, Apr 16, 2002.
  1. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    How much overscan would be regarded as 'normal'? I've probably got 15mm clipped off the top and bottom of my 28" widescreen TV.
    I checked this out by comparing the image produced when watching in 1.85 anamorphic and 1.85 letter box (watched in 4:3 without any zoom). When watching it in anamorphic mode about 15mm are cut off from the top and bottom. Is my telly being a bit overzealous, or is this a good amount to be clipped?
    I can tweak this in the service menu, I was just wondering what a 'sensible' amout of overscan would be...
    I think my telly's definitely a bit 'off' currently as when using the 'progressive zoom' feature to zoom a 16:9 letter box image the image reaches the top/bottom of the screen long before it reaches the left/right. I probably need to reduce the vertical amplitude a bit.
    Cheers,
    John
