How much is the Bryston 6B SST?
Discussion in 'AV Receivers & Amplifiers' started by nathan_silly, Jun 4, 2003.
  1. nathan_silly
    nathan_silly
    I guess it won't be cheap. :D
  2. codling
    codling
    Jul 5, 2001
    427
    hartlepool
    +15
    nathan,
    the 6b sst srp is£3850.but you can knock off at least 10%.
    carl
  3. nathan_silly
    nathan_silly
    eek! What other high quality, high powered 3 channel poweramps are there?
    I know of the Rotel 993, but I prefer a bit more detailed sound- the Rotel seems to lack something compared to the Audiolab (Rotel has higher power, but two people both though the Audiolab sounds better)
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    You can find amps like the Krell KAV 500 for around £2k secondhand,and yes nathan,I do know it's a 5 channel amp,but some of these are well worth looking at....unbreakable,and usually deliver power well in excess of their rating.
    e.g.My KMA100s have been measured at nearly 200W into 8ohms...the KAV series were good amps,not as good as the SST Brystons.....but good all the same,without the price tag.
  5. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    A few places list a 3 channel version of the 9B SST but, strangely, there is no mention of this model on brystons website.
    See here: Bryston 9B SST THX-3 channel = £2, 750: http://www.music-at-home.co.uk/html/hc/hc_bryston.html
    This would be even nicer - 6 channels but can be bridged to 3:
    http://www.hometheatersound.com/equipment/belcantodesign_evo6.htm
    The conclusion in the above link tells you just how good it is. However, looking at the US price methinks we are looking at £5K plus over here.
    Matt.
  6. nathan_silly
    nathan_silly
    Thanks. (if) my PX isn't good enough then I'll be looking for a three channel- normal powering the 2.2's, and the third for a SVS CS-Ultra. Or maybe a five channel poweramp, four to bi-amp the 2.2's, the last channel for the CS-Ultra.
    How good are multi-channel poweramps compared to several 2 channel poweramps or monoblocs though? Are several poweramps better than a single 8 channel for instance?
  7. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Have you thought of just adding a second (or even third) PX or something similar to match Nathan?
  8. nathan_silly
    nathan_silly
    Vikki you should know how many amps I've got! :)
    For a subwoofer I would like 200W+ (if) the PX's aren't powerful enough for the 2.2's I guess another PX will help, but not on the power output side of course.
    Soon find out....getting the 2.2's soon... :)
  9. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Yes I know about power ... but surely in a room that size it's more about control than power ... wouldn't have thought you'd need THAT much power.
    Usually stereo and mono-block amps are better because as they increase the number of channels of amplification, they don't increase the avaliable power from the PSU linearly. If you look at the power consumption of a 5channel amp (usually) you'll find it's not 2.5x the power consumption of the equivilent 2 channel amp. Of course at moderate levels thats not so important.
    Vikki
  10. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    If you are talking about KEF Ref 2.2's, I found that they weren't that difficult to drive - two channels of my Rotel RB985MKII THX (5X110watts) drove them with ease. Lovely speakers the 2.2's by the way - the imaging is superb.
    What about something like a bridged NAD 218THX for the sub - 780 watts (bridged) @ 8ohms!! http://www.discount-home-electronics.co.uk/hifi/Nad_218THX.shtml or a pair of them for the front 3 plus the sub?
    Or a bridged 218THX for the sub and a Parasound HCA2205 for the 5 normal channels?
    The choices are endless.
    Matt.
  11. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
  12. nathan_silly
    nathan_silly
    Ta Matt. So it looks like the PX's will be fine. Adding another PX will help. I'll look into getting another PX later on (if I can find one)
  13. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    Nathan, I advise you to take a serious look at a used Parasound amp. They make a great match with Lexicon gear and have a fabulous price/quality relation. They have built a fabulous 3-ch amp, the HCA-2003.
  14. nathan_silly
    nathan_silly
    Garmtz- I've been using a single PX with the 2.2's for two days now- they're fine. I'll change the system over so I can biamp with two PX's.
    Adding or replacing amps for the L/R could be depredatory- as the gains will be different (say Parasound for L/R, Audiolab for others)
  15. uncle eric
    uncle eric
    Try the new kid on the UK block. The american ATI company produce superb amps starting from the 1800 range (pictured) to the immensely powerful 3000 range.
    http://www.ati-amp.com/at1800.html
