how much is my avr 1507 worth ?
Discussion in 'AV Receivers & Amplifiers' started by jtfab75, Sep 2, 2007.
  1. jtfab75
    jtfab75
    Jul 13, 2004
    813
    BRADFORD
    +10
    i'm thinking of selling my denon avr1507 and speakers cause of the amount of cable everywhere.
    so whats the amp and speakers worth to put on ebay ? (had since last november)
  2. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    You may want to check in the seller/buyers part of this forum to get a feeling.
    Did you also consider a trade-in?
  3. jtfab75
    jtfab75
    Jul 13, 2004
    813
    BRADFORD
    +10
    i bought them from peter tyson would he do a trade in ?
  4. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    Best to ask directly ;)
  5. Ron240
    Ron240
    Jan 3, 2002
    3,630
    Kirkcaldy (but i'm not a Fifer)
    +472
    You dont say what make and model of speakers you have...this can make an enormous difference to your price.
    Also...you would be better off forgetting about ebay,you will do much better with aprivate ad in your local paper etc.
    If you are thinking of trading in for a different model...are you not still going to have the cable problem?
