How much is a DSP-A1 worth?
Discussion in 'AV Receivers & Amplifiers' started by kryten, Oct 3, 2003.
  1. kryten
    kryten
    Apr 9, 2003
    532
    Swindon
    +14
    I need to decide whether to repair or simply scrap my old Yamaha A1 - the display has a couple of blobs not working properly - any suggestions for how much I could get for it like this, or even when fully repaired (which will cost £200).
  2. They
    They
    Sep 10, 2002
    171
    16
    Bristol
    If its just the display you want to replace I think the part is about £26 and is a simple task to fit.
  3. rags
    rags
    Apr 13, 2003
    4,087
    London
    +304
    About £400-430 on ebay when fixed. Just sold my old A2 for £300.
  4. Smurfin
    Smurfin
    Aug 13, 2002
    20,786
    +4,157
    Sold my A1 with the dot matrix display fault for £420. Best bet is ebay, you won't get that price on here. (the A1 that I sold for £420 - I bought it off these forums a year ago for £250:D)
  5. kryten
    kryten
    Apr 9, 2003
    532
    Swindon
    +14
    Thanks - looks like I'll give ebay a go then.
  6. ChrisNightingal
    ChrisNightingal
    This reply is probably a bit late but I had the same problem with my A1 and it turned out to dry joints between the pins on the display and the board.
    I took mine to VideoTec in Oxford and they fixed it for £60
    Thanks,
    Chris Nightingale.
  7. kryten
    kryten
    Apr 9, 2003
    532
    Swindon
    +14
    Apparently its the matrix display itself so a couple of hundred quid for a replacement.
    Haven't got round to putting it on ebay yet, though over the last couple of weeks a few seem to have gone for 400-500 quid, so I guess I might get 350-450 for it.
    Thanks for reminding me!!!
