How much, how far, how high....how much help do i need :)
Discussion in 'Projectors, Screens & Video Processors' started by oreoboy13, May 29, 2002.
  1. oreoboy13
    oreoboy13
    I have just told allders to pickup my Tosh 42WH18B, the right hand side bows so i dont feel to guilty but, i am getting my money back and not a replacement if you know what i mean. When the TV first turned up i thought i was fantastic especially as i had only had a 28 4:3 b4. I soon realised the TV wasnt right for me, it was too big and intrusive just for normal TV watching and not big enough for films. I secretly knew i needed a projector, the only problem i have is that i live in rented accomodation and will do for the next 18 months.
    Anyway as i said they are picking it up soon and it means i will have £1800 quid to spend, and i want a projector and screen. This is were i ask you all for help;
    Can i mount the projector on a shelf? if so i need to know how "throw ratios" work how, far do i have to sit from the screen, can screens be mounted to the wall without doing drastic damage? (i.e what pollyfiller can repair). Is there anything else i need to think about that i wouldnt necessarily think of seeing this is my first jump in the world of projectors?
    I didnt want to make this a Panny AE100 post so for the money £1800 including screen, is there anything else i should consider, anything new to about to come out that i should hold off for? or is the Panny my best bet. You can see what i am using the projector with @ the bottom.
    If you have read this far thank you and any help would be really appreciated.
  2. Guest
    As far as mounting the screen to the wall, that is no problem. I have a 92inch screen mounted on the wall using only two size 7 screws. It needs less fixing and makes fewer holes than a shelf! So that is absolutely no problem.
    As for throw ratios, this is one of the major reasons why people opt for the panasonic---there are of course many other good reasons, but the throw ratio of the panasonic enables you to have a massive picture in a small room whereas the other projectors tend to require a much larger room in order to get the same size picture. For example, I get a 92 inch picture from only a 3 metre throw. The sony cineza would, I believe, require twice the throw distance for the same size picture.
    As for mounting the pj on a shelf, that is exactly what I do. It is inverted and resting on four blobs of blu-tac.
    Other things to consider with a projector over a rear projector are picture quality---the panasonic responds to what it is fed. Give it pictures through a htpc and, I am informed, it can produce miraculous results. However, ordinary connection through composite is not good enough for many people. I am afraid that I am not the person to ask about this as there are many people here much better qualified in this field and I shall be pestering them soon as I intend to try and go down the htpc route myself:p Svideo and componant are each respectively a step up on basic composite.
    Also, be aware that it is not possible to watch a pj like the panasonic in a fully daylit room whereas you can watch a rear projection tv quite comfortably.
    Last, but not least, reliability is very, very important. I am writing this the day after my pj blew up so bear that in mind. Overall I still prefer the Panasonic to my former Toshiba rear projection because when it works, there's nothing like it.
  3. oreoboy13
    oreoboy13
    Thank you, for the info, sounds positive, i hope you fix your pj soon.
    However new questions seem to pop all the time;
    where do you put the centre speaker, (any delay probs)?
    How variable is the throw ratio, i.e can i move it further back than 3 meters and shrink the image down to fit, or do i have to find the perfect distance, and thats why people ceiling fix?
    How much is a screen going to cost?
    Whats a grey screen?
    when you say 92", (how good wil the Ronin car chase be!!!) is that diagonal horizontal etc. And what happens when aspect ratios change?
  4. Guest
    Hi oreoboy13
    Hope I can be of some help.
    I put the centre speaker under my screen. It sits about 3 inches under the screen when the screen is dropped. Sounds fine, the sound seems to be coming from the screen, which is exactly the way I wanted it.
    Different projectors have various throws, I have read a few times that the ae100 gives a very short throw and therefore in some instances must be mounted nearer the screen than most.
    This is good for some rooms, not for others.
    My screen which is 7' 4:3 electric was £600. The grey ones are a little more expensive. (i think)
    Tend to give better contrast than white screens, but at the expense of brightness.
    I think the ae100 looks a great projector for the money, its only the reliability problem which concerns me greatly. Its great to have a 16:9 projector, I was temted to exchange mine for this reason alone but didnt due to various faults.
    I have now opted to go down the htpc route, a little user unfriendly but what a difference in the picture quality!
  5. oreoboy13
    oreoboy13
    thanks for the info;
    So if the room wasnt the right length i would have to ceiling mount it?
    Can you get 16:9 screens?
  6. Guest
    Yes or some place their projector on a table or some other suitable item in front of their seating position.
    Yes 16:9 screens are available but definitley do cost more than 4:3 ones unless you d.i.y.
  7. Geoffc10
    Geoffc10
    owl video systems do a nice 16:9 fixed frame with velvet borders. I have one. cost around £600, much better than a painted wall, after all , would you put cheap tyres on a porsche?. If you want a projector, you need a good screen. Dont let people fool you into thinking a painted wall is like a proper screen. I have tried both and the screen looks better for pic quality.
  8. oreoboy13
    oreoboy13
    how big is the screen for £600? have you got a link?
  9. Geoffc10
    Geoffc10
    Thats for a 5ft screen (69 inch diag screen).
    www.owl-video.co.uk, but they site is being sorted out.
    tel number 01826 766 123
