how much difference would stands make with kef eggs?
Discussion in 'Home Cinema Speakers' started by RonBurgundy, Aug 9, 2005.
  1. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    a simple question here guys
    how much difference would i get from using stands for my front kef eggs than if they were simply sat on an av unit?
    if i picked some up for £60 would it be worth it?
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    Stands can make a big difference, for such a light speaker I would look at some mass loaded stands if possible
  3. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    i was looking at using a set of the original kef stands?
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    The primary function of stands is to hold the speakers firmly at a fixed hight. If the Kef stands do this, then they are probably fine although in my experience, lighter speakers respond better to mass loaded stands (but not always). The aesthetics are of course a entirely separate matter
  5. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    so if i can get original kef stands for 60 is it worth the expense? looks aside?
    i could do with getting them more around screen height i think and dont particularly want to wall mount so that im free to move my system around if the need arises
  6. SKA.face
    SKA.face
    The stands will put the tweeters at ear height,and are made obviously for the KEFS,but they are way overpriced for what they are,are flimsy,and poor quality.
  7. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    but worth £60??????
  8. SKA.face
    SKA.face
    I don't think so,but if the asthetics are important,then get them,they're very skinny,flimsy,it's only the weight on the floor that hold them,how on earth they were £100 is beyond me.
