How much difference does 100W make?
Discussion in 'Soundbars, Soundplates & Soundbases' started by Scar0030, Feb 24, 2018.
  1. Scar0030
    Scar0030
    Feb 16, 2018
    16
    Malta
    I am trying to decide between the Samsung HW-K430 and HW-M450. Between these two units, there is a difference of 100W, since the K430 has 220W and the other one has 320W.
    My question is the following - there is a price difference of around 60 euro between the two units. Is that extra 100W worth it? Please consider that I would never really be raising the volume too high due to neighbours. Are there other differences which are worth the extra cash?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    'Watts Per Channel' - the gift which keeps on giving to the Marketing department!
    Connectivity (or lack of) is usually the most important 'Spec' on a budget Soundbar.
    Joe
  3. Scar0030
    Scar0030
    Feb 16, 2018
    16
    Malta
    Hi Joe - that's what I thought. Given the specs of the two sound bars, which would you say is the better choice? The M450 is 60 euro more expensive than the K430.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    Both have limited Connectivity - I would be looking at which Sources I am going to be using and where am I going to be connecting them.
    Joe
  5. Scar0030
    Scar0030
    Feb 16, 2018
    16
    Malta
    The soundbar would be connected directly to the TV, which I will be controlling from my PC. So my PC is hooked up to the tv via HDMI, and I will watch series and movies on the TV, connected to the soundbar. I will also occasionally stream songs from my phone via bluetooth directly to the soundbar.
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    Connectivity : Source > TV > Soundbar.
    Not much to choose between Optical and HDMI ARC to connect the TV and the Soundbar.
    HDMI ARC has the potential 'advantage' of CEC control but that can be a control nightmare so may force you to revert to Optical anyway (if CEC is a pain you have to disable it which in turn disables ARC).
    Joe
  7. Scar0030
    Scar0030
    Feb 16, 2018
    16
    Malta
    If it helps, both the TV and soundbar will be Samsung - so they should work together quite well.
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    'so they should work together quite well' - for ARC/CEC that may be true up until you connect a non-Samsung device to them and enable CEC (Anynet) :)
    Joe
  9. Scar0030
    Scar0030
    Feb 16, 2018
    16
    Malta
    So the bottom line is the following - if you had to choose between those two soundbars, which would you go for?
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    I would likely go with the HW-M450 as the Front ported Sub is potentially less hassle to position close to a rear wall.
    Joe
    PS Personally I'd tend to stick with a budget Stereo Amp plus a pair of speakers.
  11. Scar0030
    Scar0030
    Feb 16, 2018
    16
    Malta
    Thanks Joe - much appreciated as this is my first soundbar purchase so I am quite lost.
