Quantcast
How much better image would I get on a screen then my plain white wall?
brad123
Hi all, I have an Epson 9400 projector going onto my plain white wall, it's quite a large image as the room is big, see pic. My question is if I have a blu ray 4k player and 4k projector am I losing out just projecting onto a white wall. Would a screen be that much of a leap in image quality?
Mallardo
Simple answer - yes!
A decent screen will improve the image considerably. Your room doesn't look like a batcave so if you have a bit of ambient light in the room you might want to consider a ambient light reflecting screen (ALR).
There is loads of info about the pros and cons of different types of screen online, but I would definitely recommend getting one if you want to get the best out of your projector.
