How much bass??
Discussion in 'Home Cinema Speakers' started by KarlRobinson, Feb 25, 2002.
  1. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    If the correct way of setting your sub volume is 6db below your main speaker volume then why do some people run huge amounts of bass that surely can't used??
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Well, I guess some people just love bass. It's all a matter of preference, others find their rears to subtle and increase the volume. Though "technically" not correct it just depends how you like it.
    I suggest you set up your system to the correct levels and then tweak it according to your liking.
  3. jochem huijg
    jochem huijg
    Personally I prefer a good bass but,
    When you overdo it, especially a sub will bounce to much. At this point it will overshadow the higher tones. Go for a tight and clear bass. Its the best
